Hello HeliMLM,
thank you for your answer.
HeliMLM wrote:
the question is: in setup mode, are all the sticks shown as +/- 100% on full stick travel (or at half stick)?
Yes, in step5/10 all sticks are shown with +/- 100% when I move them to the related endpoints. In center they are showing 0%.
HeliMLM wrote:
and ist the cycling ring configured correctly?
Yes, if you mean step6/10. The leveling is done by using a swash-leveler, mechanical adjustments of the the rods and measurement of 0° with a electronic tool.
HeliMLM wrote:
you cannot check stick travel & FBL deflection on the bench at all. the heli is not moving / flying and in a special mode at this time. real deflections will only show up during flight.
Yes, I understand what you mean.
I'm wondering not about the resulting 10° but more about the situation that not the whole possible moving-way of the sticks is used for movement at this time on the workbench
Kind regards
Carsten
