It is currently Thu 21. Nov 2024 23:36:06
PostPosted: Thu 21. Mar 2024 1:44:53
hello. im wondering how and what setting do i use for a direct drive helicopter? what do i put in for gear ratio, and what do I use for sensing divider. i dont know how many poles the goo-sky rs4 venom motor has. this is my first time setting up the governor in the spirit.
PostPosted: Thu 21. Mar 2024 17:17:10
Hi
No gear -> no ratio -> 1
Ask the Goosky support.
Have a good time
Thomas
PostPosted: Fri 22. Mar 2024 10:57:04
Try this.
WITHOUT BLADES
You open the Governor/Throttle settings window.
You disable the Governor (on the top right on the window), you enter a sensing divider (2, 3, 4 ...), then you see the rpm returned il the RPM sensor window (Current rpm).
If this is in correlation with the kV and the LiPo cells, then you have the number of poles (sensing divider X2).
BUT you don't care about the number of poles because you juste want to have the correct rpm returned ...
If the rpm returned are too low, then you decrease the sensing divider.
If it's too high, then you increase the sensing divider.
Normally you should know roughly the rpm of your helicopter ...
When you have the correct sensing divider, then you enable the Governor on the top right on the window.
Hervé
PostPosted: Sat 23. Mar 2024 1:19:46
thank you for the inputs. i will try your suggestions
PostPosted: Wed 27. Mar 2024 19:09:09
well that worked like a charm. I set the ratio to 1 and keep increasing or decreasing the divider until the actual head speed matched what the spirit was saying. got the head speed with my tacometer and adjusted the divider. and it was right at 20 for the divider
PostPosted: Thu 28. Mar 2024 2:12:59
If you don't have a tach you can use Spirit's vibration Spectrum Analyser to find the vibration level of the main rotor, which will tell you the actual RPMs, then adjust.
