It is currently Fri 22. Nov 2024 19:34:47
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon 27. Nov 2023 18:07:19
Any more news on the update?
PostPosted: Mon 27. Nov 2023 19:59:03
We are still preparing it and doing last tests. Thank you for your patience.
PostPosted: Mon 18. Mar 2024 20:45:57
Hi
not sure this topic was already replied somwhere else.
I have two SRXL2 Receivers connected to the spirit. One to the normal port and the second to Sat2.
I have problems that my DX9 sometimes says that ther is no telemetry data from the ESC.
According to this threat this should be fixed?
(But i miss the final OK from the DEVs)
PostPosted: Tue 19. Mar 2024 16:06:28
there was never any issue with missing ESC telemetry but random telemetry and integration losses.
It is only needed that wiring and settings are OK if you are getting this problem.
Make sure that GeoLink support is disabled, otherwise SAT2 port is unused.
PostPosted: Fri 29. Mar 2024 14:05:13
sorry for the late reply.
Just tested it again these days.
Sometimes i see no telemtrie data or update on my dx9. The antenna Symbol is blinking or getting off on the display.
When i disconnect my receiver from the sat2 port telemetrie looks stable.
Control failover between the two receivers works fine. It´s just the telemtrie which sometimes stops.
best regards
Florian
Users browsing this forum: Bing [Bot] and 40 guests
