It is currently Sat 23. Nov 2024 4:32:08
[ 3 posts ] |
Duckman
Posted: Tue 27. Feb 2024 11:55:07 |
Hi
Just at take off head speed the tail rotates quicly to the right in a full circle. The servo direction is OK and the blades move smoothly. Any ideas of what the problem is?
senaka
Posted: Mon 04. Mar 2024 11:32:04 |
Joined: Wed 10. May 2023 9:36:53 Posts: 37 Location: The Netherlands
Could be in the config although moving the TX sticks commands the correct throw direction, the spirit may have this direction reversed somewhere in the settings?
Posted: Mon 04. Mar 2024 11:36:10 |
It could be also wrong Mounting Position configuration. Servo must compensate in the correct direction otherwise model will yaw everytime during lift off. You can check it without main blades when you will set low RPM and carefully change position. If it will not try to hold then General/Mounting position was set to incorrect one. It is better to hold tail boom very firmly and carefully. Very low RPM are enough to check this.
[ 3 posts ] |
Users browsing this forum: Bing [Bot] and 46 guests |
