It is currently Sun 24. Nov 2024 8:13:22
PostPosted: Mon 05. Feb 2024 2:38:08
Can someone help me please.
The spirit unit in My 450 scale is not operating in stability mode even though I'm pretty sure I've set all relevant to setting and fbl settings right.
-60 gyro etc. It's functions like a flybared heli.
Ta
PostPosted: Mon 05. Feb 2024 8:49:44
please attach you settings file so we can check how your unit is configured. Without it we can only guess.
PostPosted: Mon 05. Feb 2024 21:51:52
Thank you, I'll get settings and get back to you..ta
PostPosted: Sun 11. Feb 2024 15:48:40
Ta
Are you able to see it enabled and then engaged when you look at the diagnostic page ?
If not you need to get it enabled in stabi page . And if you follow the spirit online manual it should walk you through it .
If it’s set up right you will see “enabled” in the area under the green bars on the diagnostic page , then when you activate it it will change state to a blue “engaged”
