It is currently Fri 22. Nov 2024 7:54:08
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Mon 01. Jan 2024 19:45:16
Hi, I’m a newbie with Spirit units. While setting up my Spirit GT and Geolink V2 the Spirit software crashes randomly. Is this “normal” behavior?
Windows 11 pro
PostPosted: Tue 02. Jan 2024 8:13:19
could you please share any details about where it is crashing?
Are you using Wifi-Link or USB interface?
Do you have internet connection during the setup?
What Spirit Settings software are you using? (Visible in the App Window title)
PostPosted: Wed 03. Jan 2024 10:45:18
It is randomly crashing while setting up the unit. So not something I can reproduce.
I’m using the supplied usb-link.
I do have an internet connection during setup. I’m doing the setup at home.
I’m using 3.6.1
I received the unit 28-12-2023 so I’m a real newbie.
Regards,
Rolf
PostPosted: Wed 03. Jan 2024 11:04:32
One additional question, does the channel numbering matter for the Spirit?
You can see my channel assignment in the photos.
Regards,
Rolf
PostPosted: Wed 03. Jan 2024 13:08:26
It is enough to leave base channel mapping (first 6 channels) at defaults at both Spirit and Radio. Then you do not have to change anything and it will just work out of the box without any changes.
So your channel mapping is unusual but if all channels are working well then it does not matter.
Default order is from 1 to 6, where Channel 1 is Throttle. It seems the channel order is not default at both sides now. In any case it should not cause anything wrong.
Thank you for your description. We are testing current version for several months and can't replicate any crashing. So whatever you will find is very helpful.
PostPosted: Fri 05. Jan 2024 16:21:22
Hello Tomas,
with the new Spirit Settings-Software 3.6.1 it crashs randomly (It closes itself !) -
If you start the program agian it will work again till it closes self again or not - there is no reason -
With the version before 3.5.1 that never happens -
In this case I have an Spirit II with Spektrum SRXL2-satellite -
Matthias
PostPosted: Fri 05. Jan 2024 19:24:11
Could you temporarily try to disable internet connection when doing the setup?
I think the problem is related to connection stability. Maybe there are some losses that are causing this problem.
PostPosted: Fri 05. Jan 2024 22:30:58
I will try it tomorrow again without Internet and then report the results back -
Matthias
PostPosted: Sat 06. Jan 2024 17:47:04
Hi, I am having the same issues, suddenly application is closed. I am using USB cable connection.
I am also newie with the system. I only have used this last versión.
Regards.
PostPosted: Mon 08. Jan 2024 8:54:16
Thank you for your messages. Unfortunately we are unable to replicate the issue yet.
When it will close is there any crash report? Or is it looking like you are pressing Escape key?
