It is currently Fri 22. Nov 2024 1:26:10
 Post subject: throttle calibration
PostPosted: Wed 27. Dec 2023 4:20:17
can someone step me through the throttle calibration with an nx8 and a sprit fbl with hobbywing
40amp.
just not sure im getting the beeps at the right time.
ta
 Post subject: Re: throttle calibration
PostPosted: Wed 27. Dec 2023 6:15:48
First set nx8 throttle curve 0,25,50,75,100 power up spirit unit , than plug in main battery with throttle stick all the way up , beep beep than lower stick all the way down you will hear beeps all done . Make sure throttle hold is off when performing calculations. Make sure blades are off mains and tail
PostPosted: Wed 27. Dec 2023 10:54:55
Thanks heaps for the reply. Yes I seem to be doing as suggested but after I lower stick it beeps continuously. Also I may be doing it wrong. I lower the stick as soon as I here 2 beeps but if I leave it until it fully initialises that's when it just keeps beeping.
Ever had this issue?
PostPosted: Wed 27. Dec 2023 11:53:13
Have you set Hz in spirit settings to 120hz
Min throttle to 1100
Max throttle to 1140 in gov settings
PostPosted: Wed 27. Dec 2023 20:31:44
I didn't even know you had to do that in the set up of the unit, i was using the gov in the hobbywing esc that is attached. Could you point me in the right direction for a vid or something that explains a detailed setup of the unit. Does that mean you set up parameters in the unit as well as the esc for Gov??
PostPosted: Wed 27. Dec 2023 23:21:51
In spirit settings open general —
Throttle/gov window set as I explained earlier if it still doesn’t initialize
Lower min setting a bit
PostPosted: Thu 28. Dec 2023 1:45:06
I cant take the max throttle range below 1700 so not sure what the answer is here when requesting 1140?
PostPosted: Thu 28. Dec 2023 1:55:12
Max throttle stays you lower the min a few points not to much maybe 20 points
PostPosted: Thu 28. Dec 2023 11:53:59
The max should be 1940
Copy and paste from the manual....
3. Governor Settings
In the Spirit Settings open the General - Throttle/Governor window and set the following:
Throttle Frequency: 120Hz.
Throttle Range - Min.: 1100 us.
Throttle Range - Max.: 1940 us.
PostPosted: Thu 28. Dec 2023 12:15:55
Oops I’m sorry typo it is 1940 max
Users browsing this forum: No registered users and 48 guests
