It is currently Fri 22. Nov 2024 0:54:42
[ 10 posts ] |
limabean1
Posted: Wed 27. Dec 2023 4:20:17 |
can someone step me through the throttle calibration with an nx8 and a sprit fbl with hobbywing 40amp. just not sure im getting the beeps at the right time. ta
morrchew
Posted: Wed 27. Dec 2023 6:15:48 |
First set nx8 throttle curve 0,25,50,75,100 power up spirit unit , than plug in main battery with throttle stick all the way up , beep beep than lower stick all the way down you will hear beeps all done . Make sure throttle hold is off when performing calculations. Make sure blades are off mains and tail
limabean1
Posted: Wed 27. Dec 2023 10:54:55 |
Thanks heaps for the reply. Yes I seem to be doing as suggested but after I lower stick it beeps continuously. Also I may be doing it wrong. I lower the stick as soon as I here 2 beeps but if I leave it until it fully initialises that's when it just keeps beeping. Ever had this issue?
morrchew
Posted: Wed 27. Dec 2023 11:53:13 |
Have you set Hz in spirit settings to 120hz Min throttle to 1100 Max throttle to 1140 in gov settings
limabean1
Posted: Wed 27. Dec 2023 20:31:44 |
I didn't even know you had to do that in the set up of the unit, i was using the gov in the hobbywing esc that is attached. Could you point me in the right direction for a vid or something that explains a detailed setup of the unit. Does that mean you set up parameters in the unit as well as the esc for Gov??
morrchew
Posted: Wed 27. Dec 2023 23:21:51 |
In spirit settings open general — Throttle/gov window set as I explained earlier if it still doesn’t initialize Lower min setting a bit
limabean1
Posted: Thu 28. Dec 2023 1:45:06 |
I cant take the max throttle range below 1700 so not sure what the answer is here when requesting 1140?
morrchew
Posted: Thu 28. Dec 2023 1:55:12 |
Max throttle stays you lower the min a few points not to much maybe 20 points
ExCCHP
Posted: Thu 28. Dec 2023 11:53:59 |
Joined: Wed 12. Jan 2022 17:00:01 Posts: 71 Location: British Columbia, Canada
The max should be 1940
Copy and paste from the manual....
3. Governor Settings In the Spirit Settings open the General - Throttle/Governor window and set the following:
Throttle Frequency: 120Hz. Throttle Range - Min.: 1100 us. Throttle Range - Max.: 1940 us.
morrchew
Posted: Thu 28. Dec 2023 12:15:55 |
Oops I’m sorry typo it is 1940 max
[ 10 posts ] |
Users browsing this forum: No registered users and 39 guests |
