It is currently Sat 23. Nov 2024 4:32:59
[ 6 posts ] |
compuger
Posted: Tue 05. Dec 2023 15:17:50 |
Hello, I use SPIRIT GT with my HOTT MX-16 remote control. My question would be, does HOTT INTEGRATION also work with MX-16??? I can't find this option "option SENSOR at CHx". If yes, how does it work?
Thanks for the help
HeliMLM
Posted: Tue 05. Dec 2023 15:40:28 |
compuger
Posted: Wed 06. Dec 2023 9:07:16 |
Hello Michael, thanks for your quick tip. I have already discovered the instructions you mentioned and tried to follow them. Unfortunately I can't get any further. It seems that the “general module” is recognized as shown in the picture. But now I can't get any further. I also can’t find the “option SENSOR at Chx” setting. However, this setting probably only applies to the GR-12 receiver. I have GR-16 where SUMD is set to CH8. Maybe you have a tip from your experience with GR-16 and Sprit GT? Thanks in advance. Dieter
Attachments: |
compuger
Posted: Wed 06. Dec 2023 19:42:31 |
Further attempts were unsuccessful. I can't do it. Apparently it only works with the latest generation of receivers. Sorry
Posted: Wed 06. Dec 2023 20:05:00 |
It will work for sure. You only have to select correct sensor in the radio. This is desribed in radio manual. I think it is pressing of some two buttons. Try pressing two Arrows as described in our guide.
compuger
Posted: Thu 07. Dec 2023 16:34:06 |
Hello, thanks again for the support. After further attempts I finally had success. The problem was connecting the cable to the Spirit GT module. The picture on the HOTT INTEGRATION page shows a different module. Unfortunately, there is no picture of the SPIRIT GT module with the correct pin assignment to be found anywhere. (Why?) It would have been very helpful for me and probably also for other users if a corresponding photo or image were available. But now it worked. Thanks again.
[ 6 posts ] |
Users browsing this forum: Bing [Bot] and 56 guests |
