It is currently Fri 22. Nov 2024 1:38:51
[ 8 posts ] |
Konrad
Posted: Thu 23. Nov 2023 13:27:32 |
Joined: Fri 17. Apr 2020 15:37:03 Posts: 38 Location: Vienna
Most parameters are set the same for all banks. I think that everyone has forgotten to copy a parameter from bank 0 to bank 1 and 2. The comparison of the banks in the adjustment tab is very useful here. However, it would be much more convenient if each parameter had a checkbox that allowed me to select whether the value should be the same for all banks or only specifically for the selected bank. Similar to what Jeti allows with G(lobal) and S(pecific) for the flight phases.
Pking
Posted: Sat 25. Nov 2023 19:38:31 |
I like your proposition, I always have to use the bank comparison menu when I change something and want to make sure it’s the same in all banks.
Envoyé de mon iPad en utilisant Tapatalk
Posted: Tue 28. Nov 2023 18:54:11 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 566 Location: Germany
Hello, I do that in another way and it works - I safe the bank 0 local to my computer - Then I switch the bank to bank 1 and load the settings from bank 0 to bank 1 and so on - Then every now and then save back to the spirit under Unit and safe - then the most current status from bank 0 is always saved in bank 1 and bank 2 - to be on the safe side, then carry out a bank comparison to see if everything was successful. That's it! Really simple !
Pking
Posted: Tue 28. Nov 2023 19:17:58 |
Hi Mattes61,
Thanks for your method, what happens if i have differences in parameters in all banks and i want to change a setting in all the banks for the same ?
That the usefulness of the proposition…
Posted: Tue 28. Nov 2023 19:27:30 |
Hello, I would change that only in bank 0, then safe it on the PC and then reload it as described obove -
Konrad
Posted: Tue 28. Nov 2023 19:36:09 |
Hi Mattes61, I do it exactly as you describe, especially with the basic setup. But what you find simple, I find complicated and error-prone, especially if you keep optimizing parameters in different banks when flying in. I can live with it as it is, but it could be much more comfortable. Konrad
Posted: Tue 28. Nov 2023 20:11:31 |
Hello, if you will probably save the from another bank than bank 0 then I dont know if something would happen because only bank 0 has all information thru the complete setup process in my opinion - Maybe I am wrong and the other banks have it too , but I don't know it really, here I am a little unsure in this point -
HeliMLM
Posted: Wed 29. Nov 2023 7:43:35 |
just try a restore (in demo mode, no need to play with a running unit) from a file with bank 2 > complete setup is there. i guess, all the setup is present in every file, just the common parameters can only be edited when in bank 0.
_________________ cheers Michael
[ 8 posts ] |
Users browsing this forum: No registered users and 49 guests |
