It is currently Sun 11. May 2025 11:45:53
Post new topic Reply to topic  [ 233 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23, 24  Next
PostPosted: Sat 17. Jun 2023 5:08:44
PostPosted: Fri 23. Jun 2023 15:11:31
I just want to thank you for all the work that is being put into Ethos/OpenTX integration. I am using a Twin X-Lite S (Ethos OS radio) with F.BUS and have used an Archer RS and Archer GR6 receiver and the integration is very convenient to adjust things at the field direct from the radio. This is one of the reasons that I went with Spirit GT and I am glad I did.
PostPosted: Sat 24. Jun 2023 13:09:53
Hi Tomas,
is there a change that you extend the script to geolink functions, to me the correction gain for vertical and horizontal would be important.
Thanks for the really good script, works fine for me, FrSky XE with TD-MX.
Thanks a lot for your support!
Ciao
Jörg
PostPosted: Sat 24. Jun 2023 14:22:59
yes, last update was a game changer. Changing settings is now super easy. What is left is log viewer, more settings and s.port (if possible). Great work.
PostPosted: Sun 27. Aug 2023 11:56:15
Is there maybe any update on logging?
PostPosted: Wed 20. Sep 2023 21:06:02
Hi. Is their any update on logging?
PostPosted: Sat 23. Sep 2023 8:11:46
Hi, in 2 weeks we will have version for testing.
PostPosted: Sat 23. Sep 2023 23:18:55
Thankyou very much.I have noticed under the governor page in ethos the throttle range does not working correctly.If you click on throttle range it will revert to a very low number and not allow you to adjust it higher.
PostPosted: Fri 27. Oct 2023 8:31:09
Hi. I know your probably very busy with wave radio etc. Just wondering how ethos logging is coming along?
PostPosted: Sat 11. Nov 2023 22:50:25
Bump
Users browsing this forum: Bing [Bot] and 13 guests
