It is currently Mon 25. Nov 2024 18:07:28
[ 4 posts ] |
dkpodder
Posted: Mon 16. Oct 2023 15:17:37 |
Running the GTR in my Oxy5 with BK5001HV servos. When doing slow tic tocs (just learning), the cyclic wobbles a bit at the stops, and then settles rather quick. Is this normal behavior, or am I able to tune this out?
Thinking of replacing the servos for either Theta DH1 or some Nexpor's. Any advice on this?
Posted: Mon 16. Oct 2023 15:39:07 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 568 Location: Germany
Hello, I had the same problem a longer time ago with my SAB Fireball - What helps was the reducing of the headgain - for example per step max -5 points per setting till all was fine -
Posted: Mon 16. Oct 2023 18:30:13 |
You can increase Elevator Filter to 3 - 4.
dkpodder
Posted: Mon 23. Oct 2023 15:58:12 |
Thank you, I will try both suggestions.
[ 4 posts ] |
Users browsing this forum: Google [Bot] and 1 guest |
