It is currently Fri 22. Nov 2024 13:03:04
PostPosted: Sun 24. Sep 2023 9:16:41
Hi All
Is there a way to test if the RPM sensor is working?
I have always used a mutligov for nitros and to test if the sensor is working, you could move the magnet over the sensor and it would then show if it is working.
PostPosted: Sun 24. Sep 2023 9:51:02
So I found the tester option.
When the magnet is over the sensor, it shows inactive. When the magnet is away from the sensor it shows active. If this correct?
Sent from my SM-N950F using Tapatalk
PostPosted: Sun 24. Sep 2023 20:37:43
Yes, this is OK. However it is important that distance is good too if readings are not stable.
PostPosted: Mon 25. Sep 2023 2:00:51
Thanks.
I would've thought that it should be active when the magnet is close to the sensor.
Users browsing this forum: No registered users and 41 guests
