It is currently Fri 22. Nov 2024 13:34:36
[ 5 posts ] |
Digger951
Posted: Wed 19. Jul 2023 13:50:33 |
Governor setup on a vario jet ranger. It has magnet and sensor on the main gear that is on the main shaft. Would the governor be able to work that low as I only need 1250rpm head speed.
So if I pick 2 magnets and ratio of 1 and max head speed 1300 would the governor be able to work that low? As the align governor needs to be over 10500 as the sensor is normally on the engine.
Posted: Wed 19. Jul 2023 14:01:23 |
If you can get a stable readings of the RPM in the Spirit Settings or telemetry then it will work.
kay
Posted: Fri 15. Sep 2023 20:39:33 |
@ZeXx86: Could you please describe in detail what is ment by "stable reading" and how this can be made sure? Thank you very much in advance.
best regards, Kay
Posted: Tue 19. Sep 2023 15:00:50 |
You can verify that reading is stable by disabling governor and checking RPM readout with a steady throttle value. RPM values should be more or less around +/- 20. If it is for example +/- 100 then reading is not stable.
kay
Posted: Sun 15. Oct 2023 19:26:35 |
@ZeXx86: well, I do have a stable reading now, roughly +/-10 rpm after changing again the sensor and install new magnets. The log now tells noisy sensor data, how do I can I solve that?
best regards, Kay
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 56 guests |
