It is currently Fri 22. Nov 2024 12:56:01
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2, 3  Next
 Post subject: Real 800 Heli Setup!?
PostPosted: Sun 10. Sep 2023 11:59:18
Hello Tomas!
For a real 800 heli, Soxos 8.1, I need some setting tips.
How do you set Flight Style?
At what % do I set cyclig gain?
And how do you adjust Rudder Revomix and Pirouette Consistency?
Thank you!
Greetings
P.S. Is there an 800 heli in the Wizard?
PostPosted: Sun 10. Sep 2023 13:51:35
Gerorg09 wrote:
Greetings
Hi
There are several presets for 700 / 750 / 800 helis in the wizard
Have a good time
Thomas
PostPosted: Wed 13. Sep 2023 7:19:17
if you can describe what do you wish to achieve or what is wrong then we can help you more.
Usually there is nothing special for 800 class models. The only difference is higher Pirouette consistency parameter - for example from 180 - 210 should be good.
PostPosted: Thu 14. Sep 2023 16:02:08
Hey Tomas!
Yes, I can describe it somewhat.
Above Nick, the tail swings up and down.
I have tried elevator filters from 1-4, no improvement.
I have pirouette consistency at 195,
Elevator filter at 7.
What about cyclig gain? It is set to 55%.
Which heli would you recommend in the Wizard?
I fly the Soxos 8.1 with 1100-1450 rpm.
Greetings
PostPosted: Tue 19. Sep 2023 15:02:36
The problem could be too high Geometry 6°.
Please make sure that value is not too high and that it is configured correctly.
Correct settings is based on correct Subtrim (tuning) settings where you will set 0° for blades.
If subtrims are incorrect, then also Geometry will be incorrect.
What is your current value?
Lowering Cyclic Feed Forward should help too. Elevator Filter at 4 is required.
PostPosted: Tue 19. Sep 2023 16:41:29
Online
Gerorg09 wrote:
Hey Tomas!
Greetings
As a matter of interest i have just received the Soxos 8.1 kit. What main blades are you using?...
Regards Adrian
PostPosted: Sat 23. Sep 2023 10:18:02
@10x
I have the RotorTech 810
PostPosted: Sat 23. Sep 2023 10:34:27
Hello Tomas!
I have now checked everything again.
Geometry is already set to 6°. Blades set to 0°!
Cyclic Feed Forward is now set to 4!
I'll test it that way!
Further settings:
- Rudder Revomix at 7
- Pirouette consistency at 185
- Cyclic Gain 55%
- Elevator Filter at 4
- Pitch +/- 12,5
- Servo's Theta Razor DH1
Greetings
PostPosted: Sat 23. Sep 2023 12:23:23
Online
Gerorg09 wrote:
@10x
Thanks for this, I have some RT810 on my TT E820s so i can try these....
PostPosted: Sun 01. Oct 2023 9:38:41
Hello!
There has been no improvement.
Unfortunately, I can not get a setting for an 800 heli!
I have already tried for a long time to adjust a 800 heli, even then I had no success. It was a Diabolo 800.
I think I will change the system. For 800er Heli's the Spirit is not suitable.
Greetings
Users browsing this forum: No registered users and 34 guests
