It is currently Fri 22. Nov 2024 18:57:01
AndrewJohnHawes
Posted: Thu 10. Aug 2023 7:54:30 |
I have retried to get full telemetry but seem to get RPM (Have set 'gear ratio' / pinion & main), but seem to be missing still the Capacity used and Current Draw. I have not tested to see whether RPM recorded is accurate yet. Regards, Andy
Posted: Thu 10. Aug 2023 7:58:51 |
all the variables should be visible. It is enough to enable ESC telemetry in the Spirit Settings and then make sure to load all the sensors in the radio menu - Sensors menu.
AndrewJohnHawes
Posted: Thu 10. Aug 2023 10:01:46 |
Yes, I got RPM, but capacity used seamed unbelievably low and current draw still did not show!
Posted: Thu 10. Aug 2023 10:03:39 |
Very likely you are trying to see the values without main blades, am I right?
AndrewJohnHawes
Posted: Thu 10. Aug 2023 10:12:58 |
No, main blades on and spinning! No significant current draw showing. 710mm blades spinning at about 1400 rpm!
AndrewJohnHawes
Posted: Thu 10. Aug 2023 10:15:54 |
I am just charging again to test once more. I even linked Hobbywing 160A V4 into computer and upgraded software to latest version. Had previously been using programming box to set gear ratio, etc.
Posted: Thu 10. Aug 2023 10:16:42 |
The ESC sensor is quite imprecise for a low current. The higher current rating the HobbyWing ESC has, the higher minimal current is sensed. In a very rare cases it could be issue of the particular ESC. In any case I recommmend to check in a normal flight. On the ground with low RPM the measurement will be imprecise with this ESC.
AndrewJohnHawes
Posted: Thu 10. Aug 2023 11:56:49 |
I will check in the morning at the field with some circuits, etc. Regards, Andy
AndrewJohnHawes
Posted: Wed 16. Aug 2023 6:15:13 |
Double checked again today on a 7 minute basic hover flight. Recorded (on DC24) Hobbywing Capacity used: 267mAh Capacity replaced (on recharging x 2 individual 6S packs) 2 x 6S 5200mAh: 1913mAh and 1850mAh (Battery 1 and 2). I may be mistaken, but in 'Advanced' settings - Multiplier only goes to 300% or should I be going in opposite way to approx. 14%? Regards, Andy
AndrewJohnHawes
Posted: Wed 16. Aug 2023 8:09:56 |
I increased the Capacity used multiplier to 300%, and got an increased usage figure, but will need to do a proper timed flight and recharge. However, I don't think this will be sufficient. 300% is the maximum multiplier available. I think Hobbywing is just useless in the capacity recording. The Platinum 160A V4 is now discontinued, I believe, so probably won't be any more updates available! Andy
Users browsing this forum: No registered users and 58 guests |
