now you can compare these 3 logs that I insert you now
this logs are registered from the jeti ds12 radio in every moment reads geolink data and spirit
FLIGHT ONE LOG JETI
18-05-06.log [288.8 KiB]
Downloaded 49 times
FLIGHT TWO LOG JETI
18-28-29.log [264.99 KiB]
Downloaded 37 times
FLIGHT THREE LOG JETI
18-57-27.log [250.5 KiB]
Downloaded 36 times
PS
I also have videos of these 3 flights
simple hovering and normal flight because I'm testing the helicopter yet
I want to premise that the spirit says power error but in the logs the voltage is always CONSTANT.
but the serious problem is the geolink
for me these errors are false
maybe this can help this is my esc
i have Platinum PRO V4 -130A-HV (6S-14S)
https://www.hobbywing.com/en/products/info.html?id=70hobbywing it has a programmable bec from 5v to 8v now i set 7.8
in log jeti you can see tension costant 7.8v
this esc it has a servo plug - + s
one plug only s for rpm sensor
and other plug - +
I used only servo plug - + s
and plug s rpm sensor
other plug - + I haven't used it not to give current from two ports spirit.
hobbywing attaches you a capacitor which I have not entered because nobody uses it.
But geolink had the same behavior even with the trex 500 with another bec.
and then I think the servants they didn't work if it didn't go well and the log tension bec he would have detected it
