yes I use the same settings for all idles.
Than your transmitter setup is wrong, if you have same settings for all idles.
zexx86 I checked today and there are many things wrong.
1) i went out where there are satellites and while downloading logs and settings at the PC I have noticed that sometimes the blue light from fixed flashes for one second and then it comes back fixed.
I think that time it doesn't work it depends on the fact that the connection is not stable for a second.
it flashed and I noticed it by pure chance.
on my radio parameters never disappear they are stable.
the logs are stable
tension log is stable
no geolink error message
your geolinks do they have a solid blue light?I just happened to see the flash blue light just by pure chance I had never noticed you have to put yourself carefully to see it
I installed a fan on the esc can it be annoying?
2)in geolink - map why they are not recorded the new logs? in select to log view i can only see two old logs.
why?
3)I noticed the laser measurement it's not so good.
if I put my hand below the geolink laser sensor meters change to 0 but if I lift the helicopter in up meters remain 0.1 or 0.2 even if I get up the helicopter by a meter or two, while the barometer is the best one if I raise the heli one meter he marks a metre.
but this point number 3 it may depend from assembly I don't want to unbalance the geolink much.
anyway regardless of everything
I'm interested to know
i can use rescue automatic spirit gtr and rescue normal o selected by channel Together?
obviously not at the same time.
why in stabi mode i can't select selected by channel and rescue automatic either I choose one or I choose the other.
I could disable altitude limit and use rescue automatic but i want to use rescue normal too
Dr.Fleming wrote:
Check your transmitter setup, if you have in all Idl's, the same setup !
