altitude limit it has two activations ON1 and ON2 based on the channel value assigned to the switch
in general channel what is written to you? (on1 or on2)
this settings you only see them with the radio turned on
let me understand but you use altitude limit and normal recovery?
why if active altitude limit and after you use normal rescue altitude limit takes the altitude than when you activated normal rescue.
This happened to me, but the rescue normal It has always worked fine for me.
only that between altitude limit and rescue normal the priority goes to rescue normal.
but he's always been good to me.
Only if you activate altitude limit and then you activated the normal rescue you should disable and re-enable altitude limit.
But is it possible to have all these functions active?
why in stabi mode you can only choose one option
PS
please write english.
