It is currently Fri 22. Nov 2024 18:08:52
[ 6 posts ] |
Gerdklaus
Posted: Tue 25. Jul 2023 8:37:43 |
Hello Thomas, on the last attempt to take off, the heli suddenly pitched forward and damaged the main rotor blades. I didn't touch any sticks. During the test run, the swash plate trembled several times. I show that in the video. What could be the problem. In the last flights (2022) everything was normal. The heli didn't crash. Greetings Gerd
Posted: Tue 25. Jul 2023 8:40:39 |
it look like a strong static discharges.
Is your receiver wiring PWM? Or are you using a digital protocol? With PWM this kind of problems is much more apparent.
Gerdklaus
Posted: Tue 25. Jul 2023 9:35:23 |
Hello, I don't think it's static discharge. I installed an equipotential bonding. I am using a Futaba FASSTest receiver with Sbus2. Next I swap all 3 TS servos.
Greetings Gerd
Posted: Tue 25. Jul 2023 12:00:55 |
The issue is not caused by servos. I would look for receiver wiring. Please describe how it is all wired. Are some telemetry sensors used?
Gerdklaus
Posted: Tue 25. Jul 2023 12:15:17 |
I use a UniSens-E current sensor on the Sbus2. The sensor was installed in 2022 and has not flown since then. I will remove the sensor and test again.
Gerdklaus
Posted: Tue 25. Jul 2023 15:19:08 |
The problem is solved. Without telemetry there is no more shaking. One last question: When i switch the altitude limit and when i switch the rescue, does the swashplate have to go up and then down again after 1.5s? With my system, the swashplate (on the table) always stays up, so the heli would always climb.
[ 6 posts ] |
Users browsing this forum: No registered users and 10 guests |
