It is currently Fri 22. Nov 2024 18:45:31
[ 4 posts ] |
toni67
Posted: Tue 11. Jul 2023 9:25:04 |
Joined: Sat 29. Apr 2023 21:36:44 Posts: 30 Location: CH
Hello
I am using two Spirit 2, one of them with GeoLink V2. Soxos Strike 7.1 with Spirit 2 and Tron 5.8 with Spirit 2 and Geoink. Both of them are trimmed well and flies fine. The corresponding functions are switched on and off via dedicated channels. The GeoLink worked precisely "out of the box". Position hold, Altitude hold, Return to home work well.
Now I also wanted to try the stability mode and the rescue. So far, this has worked quite well for the Soxos. The rescue also seems to be working.
It doesn't seem to work on Tron with GeoLink. I'm hovering in place at a safe height. When I activate stability mode, the heli tilts sideways and backwards and leaves the position quickly. I have to take countermeasures. I turned off the feature. When testing rescue, it's similar, the helicopter tilts sideways and pitches upwards.
If I disable the GeoLink, Stability Mode and Rescue work the same as the Soxos. To be on the safe side, I recalibrated the GeoLink at the airfield. With no visible success.
What is the cause? Have I configured something wrong? What's the diffrent between F:Stabilisation (xx) and F:Stabi Function? Thanks a lot for your help.
_________________ Have a good time Thomas
Posted: Tue 11. Jul 2023 9:29:05 |
toni67
Posted: Fri 14. Jul 2023 11:46:34 |
Hi ZeXx86 thanks for your advise.
After reading I checked the mechanical setup and can say: its perfect. I'm now at the flying field, checked the Spirit and Geolink setups and do the first flight. And.... Nothing. No malefunction. Everything is pretty well with active Geolink. Pos hold, altitude hold, stability mode and rescue works fine.
I don't know what changed. I will have a look on that.
Thanks. Bye bye.
Posted: Fri 14. Jul 2023 13:08:31 |
Thank you for the message. It could happen for example only after certain maneuvers and certain headspeed. This can play a role.
[ 4 posts ] |
Users browsing this forum: No registered users and 64 guests |
