MichaelT1960 wrote:
I have a new Spirit 2 and Geolink V2 mounted in a OMP M4. The helicopter works fine in Normal flight Mode (hovering).
Switch pos 2: Idle up from normal / Bank 1/ Pos and Alt Hold
Switch pos 3: Idle up for 3d (I am a beginner) / Bank 2, with rescue using and AND with another channel switch position.
I know the manual says to make sure you test the Altitude Hold and Position Hold first with some altitude.
When I engage both of these in idle up with a constant head speed the helicopter does not want to lift off, and seems to veer to the right somewhat.
When I did get it to gain altitude it wasn't very stable and I couldn't find the altitude hold spot on the stick.
Does this feature have to be engaged with altitude first for it to work? Any ideas what am I doing wrong??
I have not brought the heli to the flying field yet to bring it up and test the Geolink, I need to get a laptop first for tuning.
When Geolink does work correctly how well does it hold the heli in place both altitude and position?
Hi Michael
My GeoLink is working good in my Tron 5.8.
You've assigned 2 functions to the same channel. This may be the reason of malefunction. "Altitude hold" has two states of working depending on the programmed value: -100% and +100%. At -100% the pitch control is by the system without any exeption.
Is it right that you've combined GeoLink functions to the different flight modes permantly active? In my personal opinion, it would be better to separate this. In case of malefunction you can switch off and land normaly. Sometimes electronics don't make what you expect.
Bye, Thomas
