It is currently Fri 22. Nov 2024 18:48:00
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Mon 19. Jun 2023 13:21:03
ZeXx86 wrote:
thank you for the video.
Can you try to view the Logs when GeoLink has no acquired satellites?
The behavior is quite strange and shouldnt happen normally.
Are you using original GeoLink cable?
Hi yes the issue is the same with sattelite fix or none, I'm using a sattelite cable at the moment for the length which is 18" I have tired it with various other cables with the same plug but different thickness and it's the same, the GeoLink function works when triggered in flight (just needs fine tuning)
I really could like to view these logs as I use the machine for speed runs, is there no other way I can get the data off the geo link?
Many thanks for the help
PostPosted: Tue 20. Jun 2023 10:42:09
there is no other way to download logs.
Unfortunately we never encountered this problem.
Some older GeoLinks could have oxidized connectors when stored in higher humidity. Then transmission has too many failures and this problem can happen.
How old is this GeoLink, was it crashed previously?
In any case original cable is recommended. Using longer cable will result exactly in this kind of problem.
PostPosted: Tue 20. Jun 2023 10:51:08
OK thanks for the reply, I will yet this geo link on another machine I have, and I will try a new V2 I have on my speed bird and let you know
PostPosted: Tue 20. Jun 2023 10:57:25
If it will work with other GeoLink then problem is likely in the GeoLink. If same result with all of them then we have to look somewhere else.
It is great you have other modules for comparison. It is enough to replug cable from one to another unit.
PostPosted: Tue 20. Jun 2023 11:05:40
Yes I have 3 spirit GeoLink in my armoury, 1 is a V2 and the other 2 are V1,
I went out last night and tested the other 2 on my other helis so will check shirtly for stored date from the flight's
PostPosted: Tue 20. Jun 2023 11:06:22
Issue is with this one it's a faff getting the geo link out of the body as tail has to come apart
Users browsing this forum: No registered users and 59 guests
