It is currently Fri 22. Nov 2024 18:32:26
PostPosted: Mon 05. Jun 2023 20:32:07
Anyone in support know the answer?
Why doesn't my helicopter leave the ground.
Lifts off fine in normal mode with these settings off!
Michael
PostPosted: Tue 06. Jun 2023 6:58:38
You can NOT have it active while on ground! Only use it while youre in the air
PostPosted: Tue 06. Jun 2023 12:04:05
Someone finally answered my question!!!
Thank you!!!
Michael
PostPosted: Tue 06. Jun 2023 15:13:05
Well.. it says it self.. if gps has locked.. and yoi activate GPS hold on the ground.. what you think is gonna happend heheh..
It stays at the position you tell him to. And your RETURN TO HOME wilø come directly above where you took off
PostPosted: Thu 08. Jun 2023 18:02:02
Quote:
Can Position and Altitude Hold be engaged on the ground?
Simple answer - it is not recommended, especially not altitude hold. Because it will hold altitude and you will be unable to lift off...
PostPosted: Fri 09. Jun 2023 17:49:20
Doesn't it matter what mode of altitude hold is selected (1 or 2)?
In the manual it says that one allows collective pitch changes and the other does not!
Michael
Users browsing this forum: No registered users and 77 guests
