It is currently Fri 22. Nov 2024 23:28:16
PostPosted: Tue 30. May 2023 19:09:25
Hi, I would like to ask you guys what is gone a be the voltage in the tail servo port of spirit 2 fbll if the supply voltage of the unit is 8.4v? Is any internal bec in the spirit unit which keep tail servo voltage close to 5 volts? Thanks
PostPosted: Tue 30. May 2023 19:50:22
The input voltage of the Spirit will be the output voltage to the servos. There is no buck or boost converter in the Spirit FBL.
PostPosted: Tue 30. May 2023 21:23:33
Thanks for your response
Users browsing this forum: No registered users and 45 guests
