Hello I have two questions and I hope that I will be clear enough.
1/ What do I need to use "Open Flight Viewer in the 3D Player from the Advanced flight Viewer feature ?
I have triggered a lot of logs but I actually don't have any telemetry feature. So I assume that the issue comes from there ? What would I need to be able to replay a flight in 3D ?
The other question about Automatic Rescue.
I'm using a Futaba T14SG with rescue triggered by a switch on bank 0 (everything is working perfectly well).
I would like to enable automatic rescue on bank 1 to make some tests, but when I switch to Bank 1 it does not seem to work.
My way of doing the test :
I take off, fly to 10 meters high and then switch to bank 1 (which has the automatic rescue configured and as I understood should save the altitude). I go 10 meters higher, but when I go below the saved altitude, the rescue does not trigger.
My feeling is that I cannot have automatic rescue working if I have switch rescue configured on bank 0.
Could someone help me please ? Is it possible ? Do I understand well how automatic rescue works ?
Any advice will be welcome given that I'm new to RC helico
Edit : To have a better understanding maybe I should add what I would like to have :
Bank 0 => channel 8 to use rescue manually
Bank 1 => auto rescue activated by default, so when I switch to bank 1 to saves the heigth.
But with wy futaba T14SG I don't see how to be able to setup that. And if I use gyro gain to enable rescue mode instead of a dedicated rescue switch, then I will be in bank 1 with gyro with gain = 0.
PS : Special thanks to the team in charge of the development of this gyro. It is really awesome and provide a lot of confidence while flying.
