trex 500e.4ds [255 Bytes]
Downloaded 38 times
thank you but sincerely I think with another geolink I will have the same behavior.
My geolink reads perfectly the height, latitude Longitude works well barometer and laser.
If my geolink it would be bad do not you think that should give me of values strange?
yesterday while I was flying i saw the height on my radio (in real time) and geolink reads the height well.
Can I ask you who do you tests?
it's just maybe that you have tried with an older firmware version and at the time it was fine.
After the updates maybe it hasn't been tested anymore altitude limit of the geolink.
When I create software after an update although I haven't touched that function due to a code change one thing that was fine before, after that it doesn't go right anymore.
With version 3.5.0 and version geolink v2 1.3.3
you did some tests of the altitude limit of the geolink?
can you ask for a test?
I used on1 and I tried either to leave 0 (geolink-aid-altitude-lowlimit) either to vary that number and write 5 meters.
You can take a test with those settings and versions?
I turn on the model at the point where it has to take off, and i always turn it on always in a level spot, no slope (I show it in the video).
absolutely I don't turn on in one point and then after I'm moving it.
The model I keep it at home to avoid problems of humidity, of heat, of cold.
If it's hot in the summer I turn on the air conditioning and the model is in the room with me.
I don't use garage for my models to avoid those problems.
I have read the whole guide of the spirit ,the geolink, radio preparation ecc ecc.
I've been trying every day for months.
Every day to understand where I'm wrong.
I'm going to fly , I get to the height where I want activate the altitude limit and activates normally.
If I return to that altitude he activates normally up to here everything works fine.
But if I now I start to fly I start doing some flips, that piro flip maneuver where it is used command of tail and aileron and elevator.
After some of these maneuvers the altitude limit of the geolink it does not activate at the height where I had activated it.
an example if I had activated a 5 meters he no longer respects the 5 metres but it starts to activate at 15 meters, then after at 10 meters, after at 20 meters, begins to activate at random height and it becomes impossible to fly because it always turns on.
For not to activate it I should go to heights type 20meters,30 meters but these heights they are too far away you start not seeing a 500.
If I activate it and normal flight, no flips, no tik tok, ecc ecc altitude limit it always activates at the right height.
I don't think it's defective.
And I understand that problems can happen each flybarles may have problems the important thing is to work on solving them.
If you tell me see your tests and I do not have problems I agree with you.
Unfortunately I have no comparison I have not got anyone to confront me.
I can only ask here in this forum.
I no longer go to the other forums why everyone he tells me about his experience whether right or wrong, while you created it only you can tell me the right thing.
all experienced pilots that I know (met online) they say to me "no i don't use auto rescue".
So let's try to understand your test results.
I would like to fly without the fear of falling.
I have altitude limit in the case of I don't make it in time to push the switch of the rescue normal
these functions they use them people less experienced in 3d flying, and you can't compare them to those who use them in fuselages
