It is currently Fri 22. Nov 2024 23:37:33
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
PostPosted: Tue 16. May 2023 13:24:31
ExCCHP wrote:
Your blade grips should have "Align" printed on them as shown in the picture above. This should be at the top. As others have mentioned you have them installed upside down (reversed). This will orientate the blade links to be on the leading edge. Not the trailing edge as you have now. This is the source of your problem.
yes we know.
I've explained it 100 times now.
it was a flybar head and after i only found t hub and the levers.
Main rotor holder they cannot be bought and I used the old main rotor holder of the flybar head.
And they can only be mounted in this mode.
I need of others main rotor holder for solve
I have already paid 70 euro (76,18 dollar) for two main rotor holder (with that money I I could buy a complete head) in italy one head complete I could take with that money but align it's in crisis, it's going bankrupt, I don't understand why it doesn't send more spare parts
PostPosted: Tue 16. May 2023 19:56:42
franz88 wrote:
yes we know.
Seems I offended you which was not my intention, just trying to help.
That must have been explained in another thread as it is not in this one.
Wish you the best and hope you get it sorted out.
Cheers
PostPosted: Wed 17. May 2023 9:02:56
no, quiet, I'm not angry.
I am waiting the pack to change spare parts.
zexx86 but if HeliMLM set in this order:
subtrim (tuning)
geometry 6 tuning
collective pitch
cyclic ring (tuning)
if i move collective pitch and cyclic ring these 2 settings may vary geometry 6 degrees?
is it correct to use this order? (this is the order of the wizard)
but you solved the problem?
You can take pictures of the servo at 90° (select subtrim tuning to have a precise center)
and photos of the various tie rods and leverages.
I've had similar problems in the past because to the elevator control horn in a different position.
You may have horns that aren't perfectly straight, the photos are used to understand if they are straight
PostPosted: Wed 17. May 2023 11:07:21
If you have different angles than the heli is not perfectly perpendicular to the side if you measure the pitch in direction of the boom - also the two blades have to have both 0° - Is the heli perpendicular to all directions you won't get any differences if you swing the blade from behind to the front -
PostPosted: Wed 17. May 2023 14:04:48
Bladecrasher wrote:
When I'm at step 8 in the wizard setup and adjusting the value to reach 6 degrees, what is wrong with my setup when I have -6 showing when the gauge is on the back blade, but when I swing the head around 180 degrees and have 10.9 degrees when the blade is forward?
All the other setup values seems pretty close.
Thanks.
For me this problem It is caused by the aileron and pitch servo which are not at 90 degrees (with blade on tail and nose).
But we wait photos of all three servants with stick in the center and curve pitch 0-25-50-75-100.
Get as frontal as possible when you take pictures of the servos, we need to figure out what the problem is.
And if you please attach your settings file
Users browsing this forum: Bing [Bot] and 52 guests
