It is currently Fri 22. Nov 2024 0:50:11
PostPosted: Mon 15. May 2023 3:04:24
I just installed the Spirit GT FBL using FrSky (ethos) radio and FrSky Access RX. I made it through Screen 5/10 of the wizard. I see stick movement and have adjusted limits, etc. When I power on my heli (esc) and lipo, I get power to the FBL and my rx has a green light. When I move my radio sticks, I do not get any movement on my servos at all. It appears that the Spirit GT fbl is not seeing my radio/rx once powered on. I still get the movements on wizard screen 5. Any thoughts?
randall
PostPosted: Mon 15. May 2023 5:59:30
http://manual.spirit-system.com/index.php?title=Wiring#CONNECTION_OF_FRSKY_F.PORT_RECEIVER
or:
http://manual.spirit-system.com/index.php?title=Wiring#CONNECTION_OF_FUTABA_S-BUS_RECEIVER
It depends on how you set the output from the receiver and the connection mode set in the GT unit, whether s.bus or f.port ... Or you can have it connected after the "old" via PPM...
Users browsing this forum: No registered users and 34 guests
