tomas I changed my head
I made sure that the laser has no obstacles
I did the setup from 0
I decreased the vibrations
now if i use 2500 rpm i have 40% vibration if i use 2600 rpm i have 60-70% vibration.
but I always get the same result
the helicopter flies great
but if i active altitude limit geolink during a flight 3d it activates at the wrong altitude.
If i I fly normal and I don't do any 3D maneuvers altitude limit it always activates at the desired height.
But you have a video of the limit altitude during a 3d flight?
during normal flight (no 3d) if i active limit altitude at 5 metres every time I get to 5 meters altitude limit activates and is PERFECT
but if i use flight 3d and active altitude limit at 5 metres sometimes it activates at 15 meters, other times 10 meters, during 3d flight is unpredictable.
I can see tests during 3d flight?
PS
I also have videos
this is video during 3d flight and when it behaves bad
https://youtu.be/N4jsigR-XAIthis is video during normal flight and when it works well (2 minutes and 42 seconds)
https://youtu.be/RfNbROVy7Uswhen it goes straight up it means that it is activated limit altitude
in the first video I tried to change 0 meters and set 5 meters.
In the second video i set 0 meters and i came back again to the hard deck variable
