It is currently Sat 23. Nov 2024 0:23:22
PostPosted: Fri 12. May 2023 1:01:01
I have a Spirit GT which I think was running 3.4.1 firmware.
I was having issues where the unit appeared to initialise but I could not move servos using transmitter.
After several attempts powering off system and repowering unit everything worked fine.
I was concerned so I tried to update software and firmware to 3.5.0
Update reported successful with a solid blue led on Spirit GT but Software will no longer connect to Spirit GT.
Repowering unit results in blue flashing led and no communication.
I have tried recovery mode several times but still not working.
How do I get my unit working again?
thanks
PostPosted: Fri 12. May 2023 8:24:46
could you send me .spirit-flash.cfg file from your Documents directory please?
I will send you instructions how to fix the problem to a private message.
Thank you
PostPosted: Fri 12. May 2023 8:54:52
Thanks for prompt response.
Unfortunately I do not have a .spirit-flash.cfg in my documents folder.
Alan
PostPosted: Fri 12. May 2023 9:00:18
Do you have a spirit paper box? There is serial number written there. We will need it if possible.
Could you also send your IPv4 address to a private message? We will assign special firmware there which should resolve the issue.
You can find it at this page: https://whatismyipaddress.com/
PostPosted: Fri 12. May 2023 9:28:09
PM Sent
thanks
Alan
PostPosted: Fri 12. May 2023 17:34:40
Thanks for the special firmware.
It almost worked.
I've sent details of the issue via PM
thanks
Alan
PostPosted: Fri 12. May 2023 23:47:03
Thanks again for the excellent troubleshooting support.
Everything appears to be working as it should now.
It turns out I had a defective BEC cable.
Alan
PostPosted: Wed 17. May 2023 14:31:41
yesterday I updated one spirit gt at 3.5.0 and everything worked for me
Users browsing this forum: No registered users and 51 guests
