It is currently Fri 22. Nov 2024 23:20:40
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Wed 10. May 2023 8:09:51
This is a digital protocol. Are the centre frequently and endpoints not defined in the receiver specification as a known constant values?
PostPosted: Wed 10. May 2023 8:18:19
They are not defined, actually each manufacturer have these values different. And some radios allow to change these centers.
But it would be enough if the radio manufacturers would define absolute values for min, max and center. But they still insist on analogue value conversion from PWM signal.
Other problem is that even temperature is changing readings. So different day center can be at a very different position.
Other channels are not critical for steering and are not usually affected by drifts like these that are controlled by sticks, so calibration is not applied there.
PostPosted: Wed 10. May 2023 8:32:16
Mattes61 wrote:
Hello azaz44,
you are right, the other channels except RUD, ELE and AIL don't center automatically, thats also my realization -
The best idea would be to center all channels automatically then that would be logical and consistent -
Why is this not implemented, what is the reason ?
I think this is not even possible. Spirit calibrates it at power on, and RUD, AIL and ELE are at zero at this time. Other channels are not.
PostPosted: Wed 10. May 2023 8:41:19
As I understand Tomas, the zero points are probably calculated from the existing min and max values, not via the real zero position, so it doesn't matter what the middle frequency is in the end -
PostPosted: Wed 10. May 2023 9:00:21
I don't think they are calculated from min or max. Spirit looks what are values of RUD, AIL and ELE when it's powered on, and assumes these are zeros. Your sticks are better centered at this point. And it also estimates PITCH center from this.
I think main reason for doing this is to account for gimbals with potentiometers, where this center value can change a bit over time. Hall sensors are much better and maybe wouldn't need this calibration, but not every radio has them.
PostPosted: Wed 10. May 2023 9:02:55
tomas wouldn't it be better leave in the wizard the list central impulse servo but in the advanced add an editable field where to write for the central impulse 1518 or 1520 or whatever value we want.
So we have centering for each type of radio.
it's a idea
PostPosted: Wed 10. May 2023 9:10:45
I am afraid we dont want to make things complicated.
It worked in the way as it is now without any problem for over 12 years.
PostPosted: Wed 10. May 2023 10:01:19
Tomas would it be possible that you explain how auto center will work ?
Thanks !
PostPosted: Wed 10. May 2023 11:16:05
I dont get it, why this is such a big thing
just adjust outputs so Spirit sees +/- 100 and call it a day ....
PostPosted: Wed 10. May 2023 11:31:56
Thanks for your great input...forget it!
Users browsing this forum: Bing [Bot] and 54 guests
