Rdlx3m wrote:
Pete678 wrote:
I wouldn't put any stabilisation mode on for when you are taking off. It should be set to disabled for this, as I've heard pretty much across the board any flybarless unit shouldn't have any stabilise or rescue function on when you are beginning your flight, you switch to stabilised mode if you wish once you are in the air at a decent altitude.
May i ask for what reason that is? There is no problem taking off in stabi mode. The thing you should NOT have active is position or altitude hold! That will not let you take off.
But you can have it in stabi scale. And i land and take off with it.
I'm not 100% sure but, I've seen quite a few crashes from stabilisation mode being on when taking off. I have to confess though NONE of them have been spirit units, mainly beastx and others. I've heard horror stories of this happening too along with the videos i've seen this happen. I just thought it was a given across the board but obviously not. Just ignore my comment then as it obviously doesn't happen to these units.
