It is currently Fri 22. Nov 2024 23:20:21
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun 16. Apr 2023 18:38:06
I have set up a Spirit 2 (v3.5.0) with a r-xsr f.port receiver running ACCST v1.
The spirit 2 is receiving channel information correctly. It's fully operational.
The spirit 2 doesn't seem to be sending any telemetry information back to the radio, also the OpenTx scripts are not loading (because the spirit 2 isn't sending telem back to the radio).
PostPosted: Sun 16. Apr 2023 19:18:40
we have exactly this receiver and it works with F.Port well, including telemetry and integration.
Do you have something else connected to F.Port bus?
Is F.Port receiver type configured in the Spirit unit?
PostPosted: Sun 16. Apr 2023 23:23:34
Make sure you have the connector plugged in the right way. The exact situation happened to me. in ACCST you should be on S.PORT technically
PostPosted: Sun 16. Apr 2023 23:44:54
My r-xsr is connected as follows:
https://oscarliang.com/wp-content/uploa ... 24x591.jpg
Code:
Un-inverted smart port -> Spirit 2 ELE/PIT/AIL top pin
RX Power               -> Spirit 2 RUD top pin
RX Gnd                 -> Spirit 2 RUD bottom pin
Receiver is set to "FrSky F.Port"
I have full control, but no telem.
PostPosted: Mon 17. Apr 2023 12:58:04
Maybe problem is here:
RX Power -> Spirit 2 RUD middle pin
PostPosted: Mon 17. Apr 2023 14:32:20
Sorry that was a typo. The power is connected to the centre pin.
PostPosted: Mon 17. Apr 2023 14:38:03
Did you updated r-xsr with last FW ? And did you put rx in f.port mode?
PostPosted: Mon 17. Apr 2023 20:17:35
Here are all the software versions that I'm using:
Spirit 2 v3.5.0, 4ds file attached.
500x fport with stab.4ds [255 Bytes]
Downloaded 40 times
R-XSR:
I'm running RXSR-FPORT_LBT_ACCST_191128.frk from here:
https://www.frsky-rc.com/wp-content/upl ... 191128.zip
The receiver is showing a green and a blue LED, which I believe means green=bound, blue=fport.
Transmitter:
Running OpenTx 2.3.14, and Spirit integration https://www.spirit-system.com/dl/opentx ... 4.3-en.zip
I have full channel control of the Spirit 2, all channels are working, so the receiver must be outputting f.port to the spirit, but the spirit isn't sending telem to the receiver.
PostPosted: Mon 17. Apr 2023 23:25:27
Try this ACCST D16 v2.1.0, ACCST D16 v2.1.1(F.Port firmware update only )
GT 3.5 + R-Xsr 2.1.1 LBT and EdgeTX 2.8 integration 3.4.3 everything works great.
PostPosted: Mon 17. Apr 2023 23:42:13
Just flashed the transmitter to ACCST v2.1.0, and the r-xsr receiver to "RXSR_ACCST_2.1.1_Fport_LBT.frk."
https://www.frsky-rc.com/wp-content/upl ... v2.1.1.zip
I have full control of the model, but no telem is being sent back to the radio.
Users browsing this forum: Bing [Bot] and 51 guests
