It is currently Fri 22. Nov 2024 23:25:41
[ 8 posts ] |
weixelgeist
Posted: Fri 07. Aug 2020 9:49:38 |
Hi I am on Android Spirit Settings 3.1.0 with Wifi-Link I cannot find out how to switch the Banks, the app is always on Bank0 Thank you, Gerhard
Posted: Fri 07. Aug 2020 10:10:17 |
It is enough to swipe the screen to the right side.
weixelgeist
Posted: Fri 07. Aug 2020 10:26:01 |
It works, thank you. Another question: I have set the Wifi-Link Modul to 60sec Auto Switch Off But the modul does not switch off.
Posted: Fri 07. Aug 2020 10:35:55 |
You have to disconnect from the module. If you have set up also Wifi Client then you have to disconnect client - or go away from the AP.
weixelgeist
Posted: Fri 07. Aug 2020 11:28:31 |
amelin@macks.be
Posted: Mon 12. Apr 2021 9:22:53 |
Hello, I have the same problem, not able to change bank ! Android on One T 7 plus. Swiping to the right, up, down or left, there is no swipe possible. Swipe what ? All screen ? Just a specific place of the screen ? Thanks for help.
JoergZ
Posted: Fri 14. Apr 2023 10:24:56 |
Joined: Wed 09. Jun 2021 8:51:13 Posts: 30 Location: NRW Germany
it is an old task but i have today the same irritation...
I had the same problem of being able to view the banks by swiping to the right. Navigating by swiping was enabled on my ONE+. This reliably prevents this menu function from 'Spirit-Settings'.
I switched to 'navigation via symbols' and then >swiping from left to right< is working and i am able to select Banks...
New phones no longer have navigation icons. Please show an info about it. Perhaps also simplify switching B0/B1/B2 via fixed icons in the upper area. Greetings
Posted: Sat 15. Apr 2023 7:34:32 |
no buttons are needed to access the menu. You only need one finger - put it at the left side, center of the screen and then move to right. This will open the menu.
[ 8 posts ] |
Users browsing this forum: No registered users and 50 guests |
