Hi all,
The original question was for the NEW way to set up the stabi mode.
So there is a bit of confusion between the previous way of setup the stabilization and the new one, so thank Tomas to help me clear this out.
Stabilization will help based on the skills and what you really what to archive (scale fly, 3D, beginners, panic...)
keep in mind it is not hands-off-transmitter sticks and flies like a drone in one spot. That will be more of Geolink's work. so let's try to separate the two.
stabi will help with training based on your skills (normal, acro, scale...) or if you get disoriented.
rescue will help save the model in case of an imminent crash...
Old mode:
F: Stabi Function was for older activation methods.
Function in the Stabi/Function parameter will be activated by a dedicated channel selected in the
General/Channels.you will need a channel to turn ON/OFF stabi (Was a waste of a channel for receivers with less than 8 ch.) so that`s why the use of channel 5 for more channels available.
then on another channel, for stabi normal, acro, scale, and coaxial. then another channel for RESCUE with the help of a bank switching
I used to use bank switch for rescue, so bank 1 and 2 was rescue in the stabi tab. and bank 0 for stabi
old way: So let's say:
• channel 7 for activating bank 1 or 2 so then rescue
• Channel 8
for activating the Stabi function or channel 5 gyro
in this case the old way you can use channel 5 which normally is for GYRO, and use this for stabi on/off. and set up the gyro on the software and not the transmitter.
• channel 9 for activating Stabi Normal
• channel 10 for activating Stabi Acro
• channel 11 for activating Stabi Scale
NEW mode: NO need to use a channel for ON/OFF stabi.
F: stabi function not used at all
Separate channels: every mode is selected by the channel
The function must be set to Selected by Channel if functions are selected directly to channels
It is described here
https://manual.spirit-system.com/index. ... Stabi_mode let's say:
• channel 7 for activating rescue
• channel 8 for activating Stabi Normal
• channel 9 for activating Stabi Acro
• channel 10 for activating Scale
You can see which function is active in the Channels window
Based on the number of channels you will have to use the old way or the much simpler new way of setup!
alternatively for RAW fly, no stabi, but you can still have rescue, just in case.
@Rdlx3m
"RESCUE and return to home are the same thing" Response: No they are two different functions, rescue will help you save the model, and return home is on the geolink, which will behave like a drone to get back to the starting point.
maybe we can open a new post for the combination of stabi, plus geolink functions, as is still not clear to me too.
but in this case, there will be a need for more channels
hope this help
