ZeXx86 wrote:
Next update will allow configuring special Failsafe options for GeoLink to make safe return of the model possible. If model will fly away too far from the starting position and radio signal will be lost at the same time it could turn motor off.
That would be a good thing to start off with, to actually have a dedicated settings page for return to home, cuz all you have now is settings for hovering, and rescue.
But i dont use the failsafe setting in spirit. I use the failsafe command in my frsky x20. Is signal IS lost, it will automaticly switch my return to home. And under way back if signal is restored i can take over aircraft any time. Same as my drones
So far ive tested by turning off my remote while in air. And it returns.. but the hovering as mentioned is extremely violent. This was on my 700 hughes heli.
But the new one will be a much bigger turbine. And im not droping it for no reason of that price tag. So i need to make sure its stabile enough to actually function when needed;)
Ive been dropping drones when shit hits the fan . But thats usually a hit somewhere and the drone gets all crazy. Helis are differrent ball game. Every crash will cost me a minimum of 1500euro.. a minimum
