It is currently Sat 23. Nov 2024 0:51:37
 Post subject: Telemetry Data
PostPosted: Sat 08. Apr 2023 4:44:55
I am using a Spirit GT, Jeti DS-12 (Spirit version) Tx with a Jeti Duplex REX3 receiver. The receiver is connected to the Spirit unit via the E2 port. I have followed the instructions in the Spirit System Manual - Jeti Integration section 9 on Telemetry Data. The only Telemetry variables displayed after carrying out the Auto scan are S Vibes, S RPM and S Altitude. I want to access S Voltage (Main battery voltage) S Capacity (Main Battery consumed capacity). The Heli is fitted with a Hobbywing Platinum 60A ESC. Can someone tell me how to do this please.
Many thanks
 Post subject: Re: Telemetry Data
PostPosted: Sat 08. Apr 2023 7:21:01
How do you have the ESC telemetry connected and set up?
PostPosted: Sat 08. Apr 2023 7:45:18
The HW 60A ESC does not have a current sensor, so you won’t get either current (Amps) or mah consumption (capacity) using this ESC.
PostPosted: Sat 08. Apr 2023 8:00:21
look here for more information...
https://manual.spirit-system.com/index.php?title=HobbyWing_Telemetry
PostPosted: Sat 08. Apr 2023 8:23:45
He should see at least battery voltage which the 60A provides.
PostPosted: Sat 08. Apr 2023 10:00:44
Thank you all for your replies. I understand completely that I have missed out the ESC connection. I will examine the link and resolve this and advise further. Thank you all again.
PostPosted: Mon 17. Apr 2023 0:06:30
I have installed the Telem UNI cable and can now access telemetry data. Thank you again
Users browsing this forum: Bing [Bot] and 58 guests
