It is currently Fri 22. Nov 2024 18:17:45
Post new topic Reply to topic  [ 233 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 24  Next
PostPosted: Tue 04. Apr 2023 18:24:59
I don't belive, that Tomas will program a luascript for the Spirit Log for Ethos...this means effort for a "small number" of Ethos users -
It would be simpler and sufficient to write a csv file for the relevant parameters and then be able to view it in an external viewer - of course an integrated solution would be desirable, but whether it will be implemented is questionable - or someone will program something like Offer Shmuely did it at edgetx -
PostPosted: Tue 04. Apr 2023 19:49:11
Log viewer for EthOS will certainly be available along with other settings. But I cant tell you when even if it would be next week. We have so many things to do it is better to not promise anything. We are just sure it will be there, especially when OpenTX have this.
PostPosted: Wed 05. Apr 2023 6:05:20
Ethos 1.5.0 - there will also be a Log Viewer - *.csv files ...
PostPosted: Wed 05. Apr 2023 9:45:40
this are great news ! :D
Thanks !
PostPosted: Wed 12. Apr 2023 14:51:24
Why is the menu structure not the same as in Spirit Settings. Not only the Lua for openTX/EdgeTX , but also this Ethos script forces me to search for the parameters, even if it's closer.
Wouldn't it be better to put everything on one page and distribute it across horizontal pages so that everything (e.g. '<Back' , 'Save Settings' and 'Close Menu' ) always remains visible.
...how many times I got out of the Lua without 'Close Menu' and the GT keeps flashing... (and I have to go back into the Lua and exit it the prescribed way)
And please no additional query, whether the menu should really be closed. It's just so unnecessary.
Apart from the fact that the governor is not available (work is apparently being done on it), I couldn't set the limits except in Bank0 (I hadn't adjusted properly at home) because they are grayed out in Bank 1 and Bank2.
Thought it should also be possible to change these and other values in Bank1 and 2.
'Receiver Type' FBus is also called ??? displayed and is not (yet) in the menu, but you probably know that...
Greetings - you are doing a great job
PostPosted: Wed 12. Apr 2023 15:08:36
this all comes from limitations that are defined by Lua interface. We can't do magic there and it all depends on what FrSky allows to implement.
Then there are various memory limitations that we have to bear with. So for this reason it is not ideal.
But there are still things we are improving.
PostPosted: Sat 29. Apr 2023 14:51:42
Guys, for me integration doesn't work at all. X20s + Archer GR8 + Spirit Pro + all latest version on Spirit and LUA script. Telemetry works great. But if I start the script, nothing shows up. Question marks in servo type, basically no data. Is it any known issue?
PostPosted: Sun 30. Apr 2023 7:42:04
ZeXx86 wrote:
EthOS integration will not work with SPort/SBUS. This is not allowed by FrSky.
Only FPort and FBus will work with EthOS.
With OpenTX all protocols will work.
Ok, now I know the reason why it doesn't work. I do use SBUS + S.Port.
Thomas, could you share what makes a problem in Ethos comparing to OpenTX? I think it's worth raising an issue on their FrSky GitHub 'Community Feedback'. They are super responsive and resolve most probems.
PostPosted: Sat 06. May 2023 10:24:41
I opened the ticket here: https://github.com/FrSkyRC/ETHOS-Feedba ... ssues/2628
Although it would be great to have some more background for Ethos devs. For now I hope they just know about the problem.
PostPosted: Sun 07. May 2023 9:38:52
If you have spirit pro you need the intergration cable. It works. I have spirit gt and spirit pro on my helis
Users browsing this forum: mainstreet and 4 guests
