It is currently Fri 22. Nov 2024 18:58:18
Post new topic Reply to topic  [ 233 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 24  Next
PostPosted: Tue 28. Mar 2023 20:00:33
With FBUS connection the channel limits matches perfectly to the Frsky Channel limits. But the channel order from the first 3 channels is still wrong. can we correct this please for fbus?
PostPosted: Wed 29. Mar 2023 13:13:20
This will remain unchanged so that Spirit layout will be at default while FrSky layout too.
In this way no change is needed from default layouts on both sides.
PostPosted: Wed 29. Mar 2023 13:38:03
Ok.
It is verry irritating when the radio shows for example pitch is send on channel 1 and the spirit-software shows it as channel 3.
PostPosted: Wed 29. Mar 2023 13:40:08
This is because each manufacturer has own channel numbering.
Our aim is to make layout uniform with any receiver, radio, protocol.
These are only numbers that you do not have to change in any way. These numbers can be replaced with letters or anything else. But still result will be same.
PostPosted: Sat 01. Apr 2023 11:22:22
I want to have a look on the log file.
How is this possible?
I have the spirit.luac 3.4.4 on Frsky XE Ethos 1.4.7.
I cannot find the viewer.
If i connect the Wifi Modul and Android 3.5.2 i can open the viewer under diagnostic.
Is this the only possible way?
PostPosted: Sat 01. Apr 2023 11:51:17
As Ethos do not currently have a log viewer you will need to download the log file to a device where you can view it.
This can be done with the WiFi or usb connector.
Hopefully we will get a log viewer in the new Wave radio :)
PostPosted: Sat 01. Apr 2023 16:33:49
Speaking of this, @ZeXx86 Can we have some information regarding the new radio you're planning?
So far all I've seen is other folks mentioning it in various forum, but I can't find ANYTHING else regarding this future product.
Come on, Tomas, give us a little info!! :D
PostPosted: Mon 03. Apr 2023 17:50:29
I am looking for a lua script like logviewer.lua for OpenTX.
I hope that Tomas finds time to program this for ETHOS
PostPosted: Mon 03. Apr 2023 18:23:30
I found something in an other forum - you can look your ethos logs with companion (Opentx or edgetx) they seam to be compatible with it -
https://www.rcgroups.com/forums/showthread.php?3703807-FrSky-X20-X20S-X20HD-Tandem-24-Channels-with-ETHOS/page797
PostPosted: Tue 04. Apr 2023 5:12:12
I want to look at the Spirit Log under ETHOS,
not on the Ethos Log under Ethos.
Users browsing this forum: Bing [Bot] and 59 guests
