Berek wrote:
Thanks for taking time to reply.
I told you I was new and don’t really want to fry expensive electronics. So a couple of questions.
1. The cable from the ele/tail pin is a normal cable with 3 active wires?
2. The cable from the ele/tail pin Is powering the receiver or does it need its own power supply? If so will it not back feed into the spirit?
3. The cable from the ele/tail pin goes where on the receiver? A normal pin or the special jst connector on the TD R10?
Thanks.
1. No, it is not normal port. It is special port which is not carry any power.
2. No power supply to ELE/PIT/AIL port should be connected. There is no power either.
3. This port is used only with PWM connection. Your receiver allows SBUS, FPORT and FBUS protocols. We recommend using FBUS.
FBUS wiring can be found at the link I sent to you. Only stright cable between RUD port and your receiver S.PORT.
