It is currently Fri 22. Nov 2024 23:21:06
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri 24. Mar 2023 14:31:16
last week i got the last parts to complete the rebuild of my fireball and i saw that another new firmware version 3.5.0 is available. So i jumped to this version and had 3 test flights without any issues. I will do some more flights (if weather permits) and if all is ok upgrade my other Helis with Spirt GT to the new version.
Gerhard
Kind regards
Gerhard
PostPosted: Fri 24. Mar 2023 21:41:36
Static discharge could be a problem. I had mini GDW-DS595MG servo mounted on the tail taken out by static discharge before. Changed to KST servo and no problem since. Make sure you ground everything properly.
PostPosted: Mon 27. Mar 2023 7:23:43
Thank you for your input. I have the antistatic kit (connection between tail and motor mount) from Goblin for the fireball mounted and the model had more then 150 flights without issue. So its hard to believe that a static problem occured (i check regulary all of my models for loose screws, loose cables etc).
All of the (stock) servo from the kit are working without any issue.
The first flights after rebuild worked flawless (Because of bad weather on the weekend i was not able to fly anymore).
Kind regards
Gerhard
PostPosted: Tue 28. Mar 2023 10:59:13
For golfecho
I can't tell you what happened. Just a recommendation. In Jeti you can set up logging of up to four control. I recommend.
Netopyr
XL V2 700, Devil 380, Spirit GTR, Spirit RS, Spirit 2, Sir Edmunt Race, Bublinky, DS 12 a NETOPÝR
Users browsing this forum: Bing [Bot] and 49 guests
