ZeXx86 wrote:
EthOS integration will not work with SPort/SBUS. This is not allowed by FrSky.
Only FPort and FBus will work with EthOS.
With OpenTX all protocols will work.
I hate to disagree with the guy that developed the Spirit System, but
this is inaccurate. I have a Tarot 450 heli running with a Spirit 1 and it's connected to a FrSky R9MM OTA. This is a 900Mhz. It is connected to the Spirit via S-BUS, and S.Port protocol (see the first post in this thread). I have full integration, even though it's running S-BUS and S.Port, since there is no F.Port support for the 1st generation Spirit FBL.
I'm not sure where this "not allowed by FrSky" is coming from, but obviously it's not correct.
So this is still more of an issue with particular receiver units, rather than "It's not allowed". Yes, it works more reliably, or rather
with more receivers via F.Port, but it doesn't mean it won't work with S-BUS and S.port. It's likely the LUA code work more "universally" over the F.port & .BUS protocols, whereas S-BUS and S.port are more picky
