ok for now governor stop.
Listen
I have spirit rs with geolink.
Today i tried again limit altitude and the model again it went up up up up and after i deactivated it.
Today I tried other helicopter with spirit gt and I tried function rescue automatic (in stabi).
i enabled dedicated channel and after with channel signal i set 0 and 1.
If i in general channels use f: rescue automatic if i active in this mode the plate moves senselessly, in flight it is crash.
But i i active in general channels f: stabi function the rescue automatic works well.
i active in position 1 and the swashplate it goes up for a short time and after it makes you fly normal.
If i I move the helicopter down again it activates again.
In this mode is ok.
stabi mode works well but if i use f: rescue automatic it does not work.
This is equal problem in geolink limit altitude.
Why f: function it does not work?
I'll post pictures for you to understand better.
situation 1 i click disabled
i click dedicat channel and after i click apply and spirit in automatic create in channel f stabi mode
after i put in stabi - in function - rescue automatic
situation 2
i click in stabi selected channel but in this mode I am forced to use the rescue normal with stabilisation
or i wrong method or after some software update f: rescue automatic It does not work anymore, the problem there is also in the spirit gt are you sure now works? Maybe it worked fine in older versions but now no.
