In prop hanging, the full rudder deflection is required, with the faulty unit (that would NOT work in heli mode either) i am unable to get full deflection from the transmitter, only when setting the limit. one side is fine, the left side is not.
the program crashes every time you use bank switch, IT IS IMPOSSIBLE TO SET SEPARATE FUNCTIONS.
Same settings different spirit, problem gone!!???
With the same interface another spirit unit works perfectly in all banks, with separate settings.
You have an Answer for everything, but not the right ones, this is unit no 4 you can sort out when i bring them to you personally in the spring, when you demonstrate all the the things that you say work that don't
i will stay with you for a week, should be very funny.
when i tried this brand new spirit in heli mode ...
viewtopic.php?f=21&t=5479#p39566 ...every time i started the engine the pitch would stop working, another odd ball problem that disappeared when i changed the spirit out for another unit, how do explain that?
