It is currently Sat 23. Nov 2024 0:52:16
 Post subject: 3.4.4 .bin update file
PostPosted: Fri 03. Feb 2023 10:53:43
when will the .bin update file be released? Since the update to 3.4.4, my DS12 says that a .bin update is required.
I still have a GTR with 3.4.3, but this message does not appear. Only with the GTR I have changed to 3.4.4.
regards
Daniel
PostPosted: Fri 03. Feb 2023 10:57:20
this is happening because your BIN file is actually not updated to the latest one.
Please update the BIN file according this page:
https://manual.spirit-system.com/index. ... N.29_files
Then it will work well. For example after radio update it will downgrade BIN file again, so it is needed to upload it manually again.
PostPosted: Fri 03. Feb 2023 11:05:03
Ahh okay. I had updated the the DS12 to the new 5.07. That was the problem, now everything works again.
Thank you!
PostPosted: Sun 26. Mar 2023 14:43:37
Thomas...my ds24 has always said ERROR bin file update required. altho updated in studio.
today i deleted the files from the sd card and put the up dated files back, it still says the same?
i can see the updated files there, have i put them in the wrong place? when i delete them there is nothing working.
can you save the day?
PostPosted: Sun 26. Mar 2023 16:23:08
https://spirit-system.com/dl/jeti/SPIRIT-3-5.zip
Updating procedure:
Download JETI Integration ZIP archive from our web page - click at the JETI icon.
Extract the archive to your hard disc.
Connect JETI radio with USB cable to your computer.
Confirm USB connection at the radio.
Copy content of the directory SPIRIT-3.X to Devices folder in SD Card of your radio. This process must rewrite old files.
After this procedure, you should see SPIRIT.bin, REX-RS.bin files and SPIRIT directory located in the Devices.
In unit Spirit must be 3.5.0 fw ... update via SW:
http://www.spirit-system.com/download.php
Users browsing this forum: Bing [Bot] and 55 guests
