It is currently Sat 23. Nov 2024 5:01:28
Post new topic Reply to topic  [ 116 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 12  Next
 Post subject: Re: spirit rs help
PostPosted: Tue 24. Jan 2023 10:58:36
under the bioadhesive i have the base wide and long of the same measure of the geolink.
the laser sensor is locked.
Listen me if i rise high the helicopter connected to the pc the barometric sensor (the laser does not see on the ground) he has to tell me that the model is located one meter high, two meter high, it's right?
How does the geolink to take the 0?
I checked the rotation x and y axis rotation to the north, the position in map, it's all OK but I need to check the height because I've seen strange things while I was calibrating, but it doesn't mean anything because if 0 is calculated from the location where you did the calibration it's a case because I was not level ground I was on the balcony
PostPosted: Tue 24. Jan 2023 19:45:34
initial altitude is always taken from lift off. Each flight it is set again.
Calibration has nothing to do with this. Calibration is only affecting Compass.
You can use GeoLink even if laser is covered.
PostPosted: Sun 05. Feb 2023 14:14:13
I have updated radio jeti ds12 to the latest version using the software jeti studio I clicked update radio.
after i downloaded the latest jeti integration from the site https://www.spirit-system.com/download.php and is version 3.4.1
The last version spirit rs and is 3.4.4.
Now if i try to enter in the software spirit from my radio jeti ds12 spirit edition it comes out written to update (jeti integration) to the version 3.4.4 but the last version jeti integration in the site is 3.4.1
but I can still get into the software spirit from my radio and everything works perfectly.
I don't understand though why does that message have to come out?
PostPosted: Thu 09. Feb 2023 14:50:29
Altitude Limit
Quote:
1.2 Usage
The feature can be engaged at any given time by a switch of your radio. We recommend to use a normal two-state or three-state switch for this feature. But first it is important to decide in which way the feature will be engaged as there are two options:
To engage with Stabi function - in this case the feature is engaged when programmed Stabi function is engaged. This mean you do not need to assign any other switch than when used for e.g. Stabilisation mode. [LESS CHANNELS ARE USED]
To engage with assigned GeoLink channel - it is required to assign F: GeoLink Altitude Limit function in the General/Channels to an available channel. [EASIER TO SET UP]
1.3 Modes
If Altitude Limit is engaged by assigned GeoLink channel there is possibility to use two different modes for activation. In the Channels window you will be able to see Function as On (1), Off and On (2) which is corresponding to 100%, 0% and special case -1% to -100% channel value.
1.3.1 On (1) - Variable Hard Deck altitude
When On (1) is displayed it mean that Hard Deck altitude is programmed from the altitude in which the model presently is. In other words, if you engage the Altitude Limit when flying in 5 meters, the models will be automatically recovered whenever it will drop under 5 meters. This mode is very easy to set, because you do not have to set basically anything. And additionally you can program Hard Deck to any altitude at any moment even without landing.
1.3.2 On (2) - Fixed Hard Deck altitude
When On (2) is displayed it mean that Hard Deck altitude is programmed from the channel value itself. It is calculated based on the range -1% to -100% where -1% is used for the lowest altitude and -100% for the highest altitude that is nearly equal to altitude specified for Maximum parameter. As soon as you will enable mode On (2) you will also see exact hard deck altitude in the Aid Tab from GeoLink window. This will tell you in which altitude rescue will be performed. If you want to set the Hard Deck to be same each time as with older firmware version such as 3.4.1 then you are looking for this mode. Hard Deck altitude can be changed anytime if you will modify channel value.
tell me something?
if it is activated on1 is activated based on the current position of the model
on2 is activated according to the channel signal
Triggering Acceleration is 0 standard but do i have to change this value?
but if the function Altitude Limit of the geolink is activated in 2 mode which I just described the parameter return altitude (the red rectangle) what do i need it for?
i am reading this
http://manual.spirit-system.com/index.php?title=GeoLink_Altitude_Limit
PostPosted: Thu 09. Feb 2023 19:50:34
please help me
and now I would like to activate return to home and rescue normal model .
for return to home i takeoff in mode off and and I push the switch in on4 and does he go back to his starting position?
PostPosted: Thu 09. Feb 2023 20:26:09
Return Altitude is not used for Altitude Limit at all.
It is used only for Return to Home and Geo-fence features.
PostPosted: Fri 10. Feb 2023 11:26:53
I'm trying the return home, rescue normal, altitude limit.
I've noticed certain things.
1) when I take off i active altitude limit and in this moment the model goes up.
First time I activate it I'm doing to set the height.
In this moment because the model go up?
It is only used to set the height, and next times every time that goes down below that height you have to send it to me above.
2) i active rescue normal he places the swhashplate to the set percentage, when you turn it off the plate it moves very fast at the current stick position, wouldn't it be better do it sweeter?
if the model is found at 70% and the stick far below the model receives a hit violent.
I have activated the time and put the percentage after the same to the percentage before, i set rescue collective pitch and hovering collective pitch all two to 65% and before regaining control I have to place the stick to the 65% and I avoid the shot
PostPosted: Tue 14. Feb 2023 9:33:11
I tried the helicopter in flight.
I set 6 degrees of cyclic and on the radio after finished the setup i set 40 expo but the model of cyclic he's nervous.
Rotation speed is standard for trex 500 (8) , the software recommend from 8 to 12.
I should lower the rotation speed of cyclic?
40 of expo from radio there are already many.
without expo It is not possible because he is too nervous.
or are there other parameters to move?
PostPosted: Tue 14. Feb 2023 9:40:39
Could you please share your settings file?
It should be very easy to fly with default settings. But if some of the base parameter is not correct it could make dramatic difference.
I will check your settings and we will see.
Yes, there are more parameters - especially Cyclic Feed Forward and Flight Style can make difference.
PostPosted: Sat 18. Feb 2023 19:16:15
ok.
Now i want to report a bug of the spirit rs with radio jeti ds12 spirit edition.
In my first tests this thing didn't happen.
In the first tests it was good.
Now if i set gyro gain values below 0 it doesn't go in normal mode.
But it always stays in avcs.
negative values ​​come out but remains avcs.
Even if in the channels I deactivate channel of the gain sensitivity and set the gain from the software the same thing happens.
It always stays in avcs.
here is a screenshot
and here are my settings.
Obviously when I move the sensitivity from my radio the value in the software moves regularly.
i moved on first setup the limits of channel gyro sensitivity to have equal values on my radio and in the software max positive 115 and max negative -114 (to have +100 ecc)
Previously it was in normal mode now without changing anything normal mode no longer works.
The logs say nothing
PS
I do not understand why in my radio channel gyro sensitivity is numer 6 and in software spirit I have to put channel 5 .
doing so when i move the gyro gain from my radio corresponds to the movement of the software.
If i in the software set channel 6 such as gyro sensitivity the software radio gain does not match.
but remember that this mode in the first tests it was good.
maybe it's an integration of the jeti with spirit
trex500.4ds [255 Bytes]
Downloaded 39 times
Users browsing this forum: No registered users and 46 guests
