It is currently Fri 22. Nov 2024 12:33:30
Post new topic Reply to topic  [ 233 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 24  Next
PostPosted: Thu 05. Jan 2023 13:51:03
We have new version of the Lua script - 3.4.4.
Thanks to FrSky we were able to fix the issues. There were some undocumented changes in the recent EthOS versions which were necessary to implement.
You can download it here: https://spirit-system.com/dl/ethos/spir ... -3.4.4.zip
PostPosted: Thu 05. Jan 2023 17:38:52
Thanks. Tested this on my X18SE and Spirit GT and the bugs (save setting dialog not closing, and close menu dialog not closing) are both fixed it seems.
Keith
PostPosted: Thu 05. Jan 2023 18:32:21
new lua-script tested with Ethos 1.45 on Horus X10S Express -It works flawless !
Thanks a lot Tomas and FrSky !
Matthias
PostPosted: Thu 05. Jan 2023 21:12:18
Can you please also share the uncompiled LUA script?
PostPosted: Fri 06. Jan 2023 0:24:58
For those that have tested the new scripts and found them to work (or not), please qualify your results by providing additional information, not just the radio model, but also the receiver module, Spirit model and the protocol used (S.Port or F.Port).
I tested the new script with a couple of the units I had on hand, that did not work before, and they still don't:
Oxy 3 Tareq Ed.
Spirit 1
FrSky Archer RS - Access Mode FW v2.1.10 - S.Port
CC Edge Lite 50 ESC
Align Trex 550L Dominator
Spirit II + Geolink
RadioMaster R161 - ACCST Mode FW v2.1.0 - S.Port
CC Talon 90 ESC
The interesting thing was that the first time I connected the Oxy 3 unit, the BANK 0 lit up, and I though , OK, we have something, but as soon as I went to the first menu, General, everything greyed out again, and none of the fields are populated with the settings. Subsequent tries were futile.
The Trex 550 was grayed out as soon as I started the script
PostPosted: Fri 06. Jan 2023 0:45:06
Tested on:
GAUI X3
Spirit GT - FW 3.4.3, Script Version 3.4.4 (haven't updated my Spirit to the new FW yet)
FrSky Tandem X18SE - Ethos 1.4.5, TD-ISRM 2.2.2
FrSky Archer RS (F.Port) - ACCESS FW 2.1.10
Script appears to be working perfectly.
Unrelated question though... I can't find the gov settings in the script anywhere. Where is that stuff hidden? A separate menu/tab for governor specific settings would be nice.
Keith
PostPosted: Fri 06. Jan 2023 8:34:13
It will not work on S.Port until FrSky will add support for it.
They said only F.Port and FBus will be supported.
Governor menu will be added in next Lua script update.
PostPosted: Fri 06. Jan 2023 8:46:35
If someone is interested we have working F.Port on all Spirit 2, Pro, micro with FrSky integration cable.
So telemetry and integration will work also there from now with OpenTX, EdgeTX and EthOS.
PostPosted: Fri 06. Jan 2023 10:21:19
here the complete information:
XLPower 520
Horus X10S Express with Ethos 1.45
Spirit GT
RadioMaster R161 - LBT Firmware for F.Port use - D16 v2.1.0 (ACCST)
Hobbywing Platinum 120A V4 ESC
Matthias
PostPosted: Fri 06. Jan 2023 10:33:19
deleted !
My statement was not related to Spirit II ..etc. with FrSky integration cable therefore deleted again -
