It is currently Sat 23. Nov 2024 3:35:06
PostPosted: Sat 12. Nov 2022 13:08:38
I would like to use both the HOTT integration and have the telemetry data of my Kontronik controller in the transmitter. My problem: Both require connection via the telemetry port on GR24. How can I do it? Y-cable? I think I read that you can also connect and loop through the telemetry from the controller to the Spirit SAT1. Is that possible? What needs to be set there? Will telemetry then be displayed in the telemetry menu of the transmitter?
My configuration:
Kontronik Kolibri 90v
Graupner GR24
Graupner MZ24pro
Spirit pro FBL
Alternatively, I have a Jive pro 80 - here the telemetry could then be realized via the TelMe.
Thank you for your help
PostPosted: Sat 12. Nov 2022 14:27:59
you can use Spirit ESC telemetry and wire it according ESC telemetry pages for both ESCs.
PostPosted: Sat 12. Nov 2022 17:20:46
Thank you for the answer
Would this also work with the Original telemetry cable of the Kontronik Kolibri 90v if I plug it into the Spirit SAT1 port?
PostPosted: Sat 12. Nov 2022 17:25:01
It should work.
PostPosted: Sat 12. Nov 2022 18:28:56
One more question: In the telemetry settings in the Spirit, I cannot select the Kontronik Kolibri. Which setting do I have to choose?
PostPosted: Sat 12. Nov 2022 21:00:19
TelMe telemetry for all Kontronik ESCs, except standard - old Jive.
PostPosted: Sat 03. Dec 2022 18:45:36
I have now connected this - but I don't see any telemetry values (everything stops at zero - no RPM, for example). Do I have to set something on the Graupner GR24 receiver? The Sprit Manual says something about "sensor to Chx" However, I can't find this option. In addition, it says that I should set the telemetry input to General. Where do I set this?
PostPosted: Sat 03. Dec 2022 22:57:23
I'm not sure if the MZ24 works the same as the MZ32 but I had no telemetry until I watched a youtube video and realised that in the TX telemetry screens I was using the RX widgets and had to change them to the Gen widgets . Now everything works
PostPosted: Sat 03. Dec 2022 23:19:49
Yes, GEN = General sensor.
There are shorter names in some HoTT radios.
Great it works now.
PostPosted: Sun 04. Dec 2022 1:41:53
I have the MZ24pro with the GR24 (Spirit pro and Kontronik Kolibri).
Where do I have to set this with the GEN?
Users browsing this forum: No registered users and 51 guests
