It is currently Sat 23. Nov 2024 4:24:49
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon 21. Nov 2022 9:27:58
I find it strange too, but I would be interested if there is an unlinearity of the servos which are visible with swash-leveler-tool or its only an false representation of the values here in the pitch adjustment menu..
Matthias
PostPosted: Mon 21. Nov 2022 10:34:12
The Servos move exactly like the values in the software. If the value jumps so the servo.
PostPosted: Mon 21. Nov 2022 12:30:55
But then the assumption is obvious that maybe something in Spirit Settings is not working properly, maybe some pulses were swallowed - maybe Tomas should take a look at it again...
PostPosted: Mon 21. Nov 2022 18:08:03
I tried on bench with a spirit pro and a spirit gt and can confirm the behaviour
( no servo connected, just usb to spirit and a lipo battery )
when you enable the pitch adjustment check
and you move one of the adjustment subtrim slider
the others try to follow it but sometimes they loose "something"
and the more you move up and down a slider
the more the others will loose the sync
PostPosted: Mon 21. Nov 2022 18:30:34
I am not seeing that weird behavior on mine. CH1, CH2, and CH3 move in sync without any channel lagging. Maybe try reinstalling the v3.4.3 software and retest. Otherwise, Tomas may have to chime in.
PostPosted: Tue 22. Nov 2022 5:52:45
Hello.
I tried this on my SpritGT.
This problem occurred as well.
When I enable pich adjustment and move Pitch(ch1) left or right fast and then restore the value of Pitch(ch1), the values of ch2 and ch3 are not restored.
This problem does not occur in Demo mode of Sprit Settings v3.4.3.
PostPosted: Tue 22. Nov 2022 18:29:50
the problem is also in Demomode ! If you put one Slider to +10 and then set pitchadjustment and move the controller positive, then the difference always remains the same, but if you move the controller to the left everything is initially ok until the two adjusted controllers are at -127, after which the adjusted controller can also be pulled to -127, i.e the difference to the other controllers is then suddenly "0"! If you then set the direction positive again, the difference remains "0", which then doesn't change anymore...there is something wrong -
initial situation:
Matthias
PostPosted: Wed 23. Nov 2022 8:41:30
this is perfectly correct behavior.
If you reach 127 in some direction it mean this servo has servo arm way too far from center.
So you have to reposition servo arm.
It should never reach 127 in any servo if you position servo arms correctly.
PostPosted: Wed 23. Nov 2022 9:16:22
Hi
Did you see my video? I hat differences way before i reached 127 with any servo.
PostPosted: Thu 24. Nov 2022 10:32:21
Hello, I returned from vacations and I saw your video.
Behavior is not good. Can you tell me if you are using mouse to change the values or some key from keyboard?
It seems the issue is related to MacOS or some version of it.
Do you use Wifi-Link or USB interface?
Users browsing this forum: Bing [Bot] and 60 guests
